- Basic maintenance - you can't run 300 whp on old seals, hoses, and gaskets.
- Fix the intake... buy a AEM dryflow intake kit or a Blitz setup.
- Take off and replace the turbo elbow, downpipe, and exhaust with 3" units. My personal favorites are the BIC DDP for a downpipe and the exhaust from him as well.
- Add a boost controller. This could be as simple as a ball and spring MBC from DrJonez.
- Pull off your intercooler and IC pipes, replace with a decent unit and hardpipes. Talk to Aaron at Driftmotion.
At this point you should be awfully close to 300 at the wheels... probably 285, anyway. And from here it gets complicated. For the next bit you need to buy bigger injectors, some fuel lines, an AFPR, and something to mess with your air signal. My personal setup is RC 550cc injectors, and Aeromotive AFPR, stainless lines from Horsepowerfreaks for the fuel, and a MAFT Pro running on speed density plus the boost control harness from DrJonez.
Then you'll need some good tuning and you should be well over your goal.
