what numbers do you have to change to be get the fuel ratio to change for low and mids i'm idling around 11-12 and when i'm just crusing i'm around 9/10.5 so i need to know what menu i need to go in to to lower the fuel mixuter
the car has 255 walbro, 550 injectors , and i'm using the lc-1
i don't need to know what numbers to put in or anything just what numbers to change and under what title they are here are the numbers i have now i would like to know what numbers to change manual on the maft pro i'm not asking you all to figure out what numbers i need to put in unless you have a system near what i have and you might have a idea of the numbers that would work i would just like to know what set of numbers on the this list change the low and mid fuel ratio
those that have any idea of what it should be the car has: 60-1 turbo, cooleze hard pipes, 3 inch turbo elbow and down pipe, .20 bore, 550cc injectors, sperco intercooler, 255 walbro
veh sel -0
#cyl-6
disp-2.9
airfl mode- speed density
map source- gm 3bar
load srce- use map
baro mode- sea level;
f-out- supra mkIII
v out 1- use setpoint
v-out 2- use setpoint
afr srce- innovate (set for what wideband you use)
f-in mode- 20 (for timing monitor if using)
aux1 mode- trig off
setup:
mainscale- -8.0
v-out 1- 2.5
v-out2- 3.6
after start 2.2
lo load pt- 36.4
mid load- 100.1
hi load- 143
f out max- 0
fe smoooth- 30
use ve table #1
spk base- 15.0
tm base- 1.9
tm correct- 1.27
af tr delay- 0.0
afr tracking
Min TPS 2.50
Min RPM 2400
Min MAP 166.4
Lean Lim% 17.5
Rich Lim% 25.0
Gain 5.2
AFR2000R 13.6
AFR3000R 12.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 0.0 0.0 0.0
800 0.0 0.0 0.0
1200 0.0 0.0 0.0
1600 0.0 0.0 0.0
2200 0.0 0.0 0.0
2800 0.0 0.0 0.0
3400 +3.0 +3.0 0.0
4000 0.0 +5.0 +3.0
4600 0.0 +5.0 +4.0
5200 0.0 +5.0 0.0
5800 0.0 0.0 -3.0
6400 0.0 0.0 -5.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.40
TPS Delay 0.60
TPS Size 6
TPS MAP Max 104.0
MAP Enrich 0.1
Boost Enrich 0.1
MAP TPS Min 0.800
MAP RPM Min 2560
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
PT Tracking -
Idle TPS .44
Idle RPM 1088
Idle A/F 13.9
Cruise TPS 1.90
Cruise RPM 2208
Cruise MAP 91.0
Cruise A/F 14.5
Lean Delay 5.0
Gain 5.0
Lean A/F 15.0
veh sel -0
#cyl-6
disp-2.9
map source- gm 3bar
load srce- use map
f-out- supra mkIII
aux1 mode- trig off
setup:
mainscale- -8.0
v-out 1- 2.5
v-out2- 3.6
after start 2.2
lo load pt- 36.4
mid load- 100.1
hi load- 143
f out max- 0
fe smoooth- 30
use ve table #1
spk base- 15.0
tm base- 1.9
tm correct- 1.27
af tr delay- 0.0
afr tracking
Min TPS 2.50
Min RPM 2400
Min MAP 166.4
Lean Lim% 17.5
Rich Lim% 25.0
Gain 5.2
AFR2000R 13.6
AFR3000R 12.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 0.0 0.0 0.0
800 0.0 0.0 0.0
1200 0.0 0.0 0.0
1600 0.0 0.0 0.0
2200 0.0 0.0 0.0
2800 0.0 0.0 0.0
3400 +3.0 +3.0 0.0
4000 0.0 +5.0 +3.0
4600 0.0 +5.0 +4.0
5200 0.0 +5.0 0.0
5800 0.0 0.0 -3.0
6400 0.0 0.0 -5.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.40
TPS Delay 0.60
TPS Size 6
TPS MAP Max 104.0
MAP Enrich 0.1
Boost Enrich 0.1
MAP TPS Min 0.800
MAP RPM Min 2560
MAF Limit 0.00
MAF Limit/KRPM 0.00
PT Tracking -
Idle TPS .44
Idle RPM 1088
Idle A/F 13.9
Cruise TPS 1.90
Cruise RPM 2208
Cruise MAP 91.0
Cruise A/F 14.5
Lean Delay 5.0
Gain 5.0
Lean A/F 15.0
