How much does your supra weigh?
Crypton2006
294
Phoenix Az
Its pretty awesome. And if anyone tells you u cant hook up with it they dont have the right tires. I can hook in second if i ease into it with 500whp. It feels like it melts 400 pounds off the car from a 3.9
Sent from my SCH-I800 using Tapatalk
Turbo Habanero
4,229
Tucson,AZ
yeah thats what im looking for lol i have the 3.7 so im looking for the difference.
How do you know if your buying a LSD ? and how much should i expect to pay for one?
All i need is the pumpkin right? and its direct bolt in?
---------- Post added at 04:18 PM ---------- Previous post was at 04:16 PM ----------
mshaw067;1742449 said:
Well thank you for the info. I will have to wait and see. Does the r-154 have longer gears then my W-58?
It's the rear end gears
87-88 Turbo has 3.91 LSD
89-92 Turbo has 3.73 LSD
86-92 N/A has 4.30 (LSD optional)
8,898
I assume you mean taller ratios. They are nearly identical. The W series is a little shorter in 1st and 5th. A little. On your vechile tag under the hood the axle code looks something like this. G305. If the last digit is 3 or 5, you have a LSD.
Turbo Habanero
4,229
Tucson,AZ
Nick M;1742467 said:
On your vehicle tag under the hood the axle code looks something like this. G3054. If the last digit is 3 or 5, you have a LSD.
Sweet i need to find me one any way to see if its off the car?
Just in case there claiming it's one. :)
8,898
Turbo Habanero;1742495 said:
Yeah... We can bring it back
Is there a wieght difference between?
4.30 LSD
4.30 Non LSD
3.73 LSD
3.91 LSD
Not enough to matter. The difference is in the sport roof and engine. The other things also add up, but not like the roof bracing or turbo.
Turbo Habanero
4,229
Tucson,AZ
I wonder how much Champion Toyota would charge for the 4.10 or if they can get it.. i dislike my 3.73 (although 3rd gear is beast) i can tell the difference in low end accel from my 3.91 that i had in my 87
---------- Post added at 10:38 PM ---------- Previous post was at 10:37 PM ----------
mecevans;1742577 said:
The 4.3 is ok but i switch gears more than i like. I want to find a torsen 4.10 .
Is yours a 4.30 LSD?
Year: 1990
Engine: 7m-gte
Tranny: R154
Options: cloth seats, tems, abs, airbags, power driver seat)
Roof: Targa
Body: Stock
Weight Reduction: Nothing
Added Weight: Small sound system, enough tools and liquids to rebuild it on the side of the road, and a 145lb lump of meat i call a friend, and my fat ass too
Weight: Just under 4,020lbs w/ half tank of gas
8,898
If the diff is out of the car, count the teeth. If the rear axle housing is off the car, spin the input flange. If the axle mounts go together, it is a LSD. If they go opposite, it is an open differential. They go the opposite way from the free spin and the side gears walking around each other. You would have to see it to understand what I mean. But if they axles go opposite, you have an open diff.
Crypton2006
294
Phoenix Az
You can tell easy without removing the diff cover. If u turn the yoke 4.3 times to make one complete turn on the axel it a 4.30
Crypton2006
294
Phoenix Az
The ones i have seen have a big lsd fluid only sticker. Or just try to spin the axels in opposit directions if they do easy its not a lsd
