One thing to keep in mind if your in pursuit of Mpg’s is tire air pressure The higher the pressure the less rolling resistance, but the tire wears out in the center due to ballooning. Also stock width tires are going to give you the best Mpg’s, the wider they are the more rolling friction there is and the less Mpg’s. I chose 245/50-16 for my mk3 so I would get a decent amount of tire tread on the ground and some extra diameter for more Mpg’s on the highway. The other plus with the taller tires during normal driving is now I can get all the way across an intersection, past the crosswalk before I have to shift into second. On the stock tire size I had to be in second before I ever got to the other side of the intersection. I get around 20/25 on my recent JDM 7MGE swap, on the freeway at 80 I get my best Mpg.
Rick
Rick
