Well, in all the wrangling to make the radiator 'fit' in my car I created a leak. Still cant pinpoint where it is but just to get to it and try to fix it will destroy the radiator. So now I am on the hunt for another radiator that is more adept to this chassis. This was one expensive lesson learned.
Moving on without the radiator, I got all the wiring wraped up for the wideband and MAFT Pro install. Figured I would give a test fire to make sure everything was in order and waiting for a radiator. Car fired right up although with an erratic idle due to base settings on MAFT-Pro. The bad news is I have no reverse for now. Hopefully I connected the linkage to the throttle body in haste and missed. Also had a spot of oil from the engine block. I am hoping I left a fitting loose at the oil filter adaptor.
