N
Wow, I didn't even think they would work. You say they are an "easy fit"....does that mean they are a "direct bolt-in", no mods at all???bigaaron said:Yes you feel the motor more with solid mounts..... at idle, when it is reving, when it is under boost, basically all the time you will feel the motor running and vibrating everything in the car including you LOL
It's not THAT bad but it can be very annoying in a daily driver and all your passengers will comment on it. Here is another possibility:
They are completely shrouded in a metal case so they will not break, and they cost less then the stock mounts, almost 1/2 the price! They do have a rubber isolator inside but it will not seperate like stock ones do. They are a easy fit for 89-up Supras, 7m or 1jz.
We even did some slight modifications and put a set on the 7m-gte Cressida we are building:
THey are Mk4 TT motor mounts and can be purchased at any Toyota dealer.
wardog said:Aaron.....so if i order mk4 tt motor mounts they work with my 89 supra and all i have to do is cut he nipple on the botton no other mods....
Does drift motion sell these mounts or should I go to Elmhurst or Jay Marks to get them?bigaaron said:Another Driftmotion solution :biglaugh: 98 mk4 TT motor mounts fit late 89-92 mk3 Supra 7m or 1jz. They are too tall for the 86-early89 mk3. You just need to cut off the little aluminum tab on the bottom.
robeats91t said:bigaaron,
when you say the MKIV motor mount is too tall for the pre-89s, how tall are they? Did you by chance get to compare the total height of the MKIV mount to an 89+ mount? I guess they can't be too much taller or shorter if they still fit in the stock mounting slots, but I was just curious if it would drop the engine any in an 89+...
IHI-RHC7 said:I just got mkiv mounts for $52 from Champion, took about 2 minutes to modify them and the shroud that goes over them to fit in the stock mounting plate.
