Ok...I'm a bit anal and got to really looking at this sandwich plate
I dropped the Mocal sandwich adapter in a pot of water and heated it up. The thermostat started closing at 65 deg C...it was fully closed at 80 deg C. Looking closer at the design of this thing, it allows oil through to the cooler at all times...the thermostat does regulate the flow, but in a rather "loose" fashion based on resistance to flow between the cooler and filter. There is no way it's flow is as accurate as I would like for a performance motor.
I think a better option for you guys is to use the Mocal in-line thermostat (Part # MOC8AN at the link in post #13). Since it is in the feed/return line to the cooler, it will regulate flow specifically to the cooler. You will need a standard sandwich plate for the filter head.
