jdub;994404 said:I did not say that...if you are going to quote me, I expect accuracy. Please do not use my name again to support what you are doing.
Just for the record, I am absolutely, completely opposed to frequent oil changes...especially at the intervals you do. This applies to just about any car out there, including your Evo...if you have the kind of blow-by that would require this frequent of a change, you've got a lot bigger problems
JJ is correct...SAE data has shown frequent oil changes increase wear on a motor.
He is also correct in his accessment of your reasoning used to support what you are doing. I got over using my "feelings" a long time ago. You may "love" clean oil and the way it makes you "feel good", but the last thing it does is "money well spent". Until you come up with technical data to support what you do, it will fall on deaf ears...at least on this forum.
Well jdub it was accuracy. Because even your own link doesnt support what you just said. I know cause I read the entire thing. Going over it twice as we speak. And no I dont have much blow by but you will get some due to boost. This is common knowledge. And rings arent impervious to blow by especially in boosted cars so I am sure you are getting amounts of blow by as well. Is it enough to cause major problems obviously not but you are seeing it which causes oils to lose its charactaristics and additives. The oil itself remains thats why we are able to recycle it its the additives that go away.
The technical data I use to support is common sense and of course your own link:naughty:. The newer the oil is the better it is. Thats a simple plain fact jdub. Even your own link concludes that the longer the oil is used the thicker it becomes which not only looses its additives but also it becomes harder for cooling due to the loss of pressurization. Also Dr. Haas did say that we could prolly never change out our oil if we had a can of additives we could pour in. However, we dont and we would need the technology to recycle the oil which we dont personally, the recyclers do, which is why you still need to change it and change it more frequently in boosted cars.
He did say that auto companies are coming out with brochures now that say you dont have to change your oil until 7500miles and even sometimes a entire year. But even Dr. Haas replies to this that in most cases you should change your oil at least during the spring or in 5000 miles which ever comes first. And this was referring to normal road driving conditions.
So no according to your link that does not substantiate any conclusive data to support your theory. Now if you have any other link that would support I would be happy to read it. thanks buddy:icon_bigg
starscream5000;994495 said:Dr Haas didn't make this assesment the SAE did. IIRC the Dr. hasn't proven this data as being false yet...![]()
Ok as I just exclaimed to jdub please give me this link. Thanks
Ok I just read this entire link as well which is on the SAE and specifically oil and the maintainence issue.
http://en.wikipedia.org/wiki/Motor_oil#American_Petroleum_Institute
And even here it says nothing about what some of you have been exclaiming. Now it does indeed say that oil is obviously getting better and some oils can be left in for 15000miles at a time but nowhere does it say the more you change your oil the worse it is for an engine. Its just not common sense is all I am saying. And I am sure that there is nothing factually wrong with it. I guess in your eyes its a cost effective issue but it would be more cost effective if we didnt use turbos or mod a car at all so like I said to each their own.
Also there are other related links on the bottom which have oil change guide, steps to change oil, and many more. And in each oil change link it recommends regular oil change maintenance and to refer to owners manual for oil change intervals.
