Adjuster
If you use seperate 4" mid and tweeters, and have a good crossover, your sound will be much better.
I have Diamond Audio componets, and they work great with my 10" sealed box Diamond subwoofer. (the key is a good amp setup, and control of the bass seperate from the rest.)
I had to modify the stock speaker housing to work with the Diamonds. They were too deep having cast alloy baskets and larger magnets.
Also try putting some stuffing in your enclosures. It makes them "Sound" bigger.
4" front, and 5.25's in the back work with some minor trimming for most people. (Unless you have the 91 door trim and enclosures, then you can use 6" I belive.)
