how big a turbo can i add with out
Status
Not open for further replies.
It gets to the point after answering the 123,964th idiotic question even the most patient reach their limit.
This thread is a perfect example of how NOT to ask a question.
If you have NFI spend a little time browsing the threads and stickies get a small clue then ask your question that's slightly informed rather than the gibberish posted here.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
what's the mostest boost i can run? i have ebay downpipe and racin bov?
Doward
4,245
Alachua, FL
wildfire3d2 said:
thank you suprarich for helping me with that info. and for the ass clowns hahahahahahahahaha ya'll is soooo funny not
hahahahahahahaah neither is your reading comprehension.
See the threads that say 'sticky' at the top?
http://www.supramania.com/forums/showthread.php?t=20163
IJ's right - even the most patient of people gets tired of the bombardment of newbs to the A70 platform.
Now, that being said - relax, use the search feature, and understand that the 7M is a picky beast. Just slapping a turbo on and throwing money at it will get you to ::bhg:: -land in a hurry.
FYI - the size of the turbo you can put onto the side of the engine has no correlation to the pistons/valve train ;)
Have you done a compression test on the motor yet?
Jumpinjackflash
12
Grand Rapids MI
AF1JZ said:
Seriously guy, search. It's located here...
Why can't you people just answer the damn, questions? Most people have a life and would perfer to spend it either working on their car, driving their car, or just plain having fun, not searching this fricken site all day. If I had the answers I would gladly share them, and when I learn this shit I will share what I know. Stop acting so damn snobby!
5
ok, gonna try and be the only helpful person here (and I'm really f-ing bored right now, so got nothing better to do)
Size of the turbo only correlates to more lag, larger turbo = more lag.
The largest turbos all be require much higher rev limits to use them effectively. That's where your cams and valvetrain come in.
Pistons on the othe hand are fine up to about 400HP (depends a hell of a lot on tune). Stock pistons don't like detonation AT ALL.
Do a LOT of reading on turbo theory and how they function, hell I don't even know that much (since it's as voodoo science as cams are), but you need to learn as much as you can to make educated choices...
OneJoeZee
Retired Post Whore
aboard the Argama
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Thank you Joe and IJ.
You want to know something Jack?!? That there search button is there for a fucking reason. Forums aren't designed to spoon feed people. It is about putting the information out there for other members to "read". Now, for say that this topic was never covered (which is has been plenty of times), then it is valid to post for some help. There is a big difference big guy. I do as much searching and researching before I go and post a stupid thread like this. So, before you call someone "snooby", look at the big picture.
Just how do you propose I answer such a stupid question when it's obvious he has NFI at all so if I do try and answer it's going to be another 20>30 posts trying to teach him the basics if it'll sink in at all?
I've spent far too many hours "helping" people to waste time spoon feeding this sort of member if he's not prepared to at least spend a little time researching his question first.
I to have a life (of sorts).
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
JustAnotherVictim said:
Ah yes someone noticed the subtlety. :biglaugh:
I seen it too, but I thought I'd wait and see how long it took the others to notice you JDM tyte math skillz ;).
Not entirely true nowadays with BB turbos. IJ. claims to see 1 psi of boost by 1900 RPMs with his and I'm pretty sure it's larger than the CT-26 ;).
s383mmber1
3,614
Somers New York
I thought he was on a 50 trim Ct-26 :dunno:
:D
suprarich
Guest
Nov 9, 2005
2,187
ohio
I am astonished that this thread is not locked yet, can't we all just love one another and not turn this place into Supraforums. Group hug!
Turbo. Targa. Life.
SupraMania Shirt Slinger!
Apr 16, 2005
1,709
O'Fallon, MO
www.geocities.com
How are turbos voodoo science? The basic concept is VERY easy to understand. Your expelled exhaust gasses are spinng an impeller. Think of it as blowing into a pinwheel. Now picture that pinwheel being connected to another pinwheel (the inducer) by a shaft. The "fins" on this pinwheel are curved the opposite direction. Now, as that impeller gets spun faster and faster, it's also spinning the inducer, which is taking the incoming air (air intake) and forcing it down the throat of the intercooler.
See? Easy! :D
Cams are also not too hard. You've got lift, and you've got duration. The longer your valves are open (duration) the more air can come in and the more goes out. Your lift also has alot to do with what can come in and out. If you had a 272 cam that only opens 9mm, only so much can come in. But if you have a 272 cam that opens 9.3mm, you're getting more in/out.
272 is your duration in degrees, it's open for 272* of a full rotation, which is 360*, obviously.
Now, this also works in reverse. If you have a cam that's 280* 9.3 and a 272* 9.3, the 280* cam is going to allow more in/out than the 272* because it's open for longer.
My big "voodoo science" as you called it, is the actual valvetrain itself, softer spring, stiffer spring, oversized valves, etc...:nuts:
Status
