How about Jacksonville peeps?
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
87nasupra said:
going to put it on after work tomorrow. i figured out why my car overheats though. Matt told me it sounded like my fan clutch, and he was right. after i run it on the interstate for 5 mins or so, when i slow down or get off the interstate it overheats. Around town it doesnt do that because my RPM's arent that high for long periods of time. I'm looking for a BIG electric fan to put in that thing vs. a belt driven fan and clutch !!!!!!
The exhaust should be an easy bolt on......... sweet, atleast that problem is out of your life.........
87nasupra
Scotty's Garage
Mar 2, 2006
993
Jacksonville, FLORIDA !
Val, you gonna be busy one night this week? im gonna need somewhere to do the exhaust at. cant do it at work cause the BIG WIG's will be in this and next week. Can ya help ?
Have you ever heard of zigro fans ? can get a 16" can w/temp switch and relay for around $100
Measurements are 15.75" T x 16.75" W x 4" deep
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
ZIGRO??? never heard of them........ what day were you thinking of trying to insatll it???
87nasupra
Scotty's Garage
Mar 2, 2006
993
whenever you have time in the afternoon...HAHA ! Is the measurments for the fan even close to what i should run ? that fan also comes with a lifetime manufacters warranty !
Oops ! ZIRGO-not zigro
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
I am not sure about the fan size............ matt is having a problem with his clutch so i gotta go help him out as much as I can tommorow, hey you know what....it wont be hard at all to do so why dont you just pullup to my house before BJ's on SAt night????? I got 2 jacks and tools, I am sure someone else will lend a helping hand......wont you guys???? :icon_bigg
87nasupra
Scotty's Garage
Mar 2, 2006
993
Val, hook me up with the antenna........$10-ill pick it up
i got the exhaust on :wuteva: but im missing an exhaust nut so i gota put that on tomorrow.
i also got all my susp. in so i can hopefully do that tomorrow night. What did your guys at toyota say?
LMK ! ! ! ! !
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
LMK ! ! ! ! !
antenna sold to Scottie !!!!! 10$ I might have an extra exhaust nut........ it is used but it will work!!! Suspension takes a few hours so it is not something you want to do at night....... Start early morning sometime..... LMK when you work on it I have some experience with it. I will talk with my tire mounting guys later on today (when it is not hectic back there) I am sure they will do it for you.:icon_bigg
87nasupra
Scotty's Garage
Mar 2, 2006
993
Yo Val, im gonna be doing susp work tomorrow or monday at 3pm where i work....they are open till 6 during the week.........We have a lift and stuff like that so i can get it in the air.
a friend i work with is gonna help me, so i figure if i get the struts and springs assembled today or tomorrow i can put them in on monday.
I had an alignment done not too long ago.....is that gonna affect it that much?
Can i put it off a week ?
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
Your camber will be all jacked up after you put the suspension in (you can put it off for a week though)......... Do you have brand new rear upper strut mounts??????? I guess my question is how are you going to assemble them without the stock bump stops and the shock mounts??? BY the way i have 3 rear upper shock mounts that I am selling for 10 $ a piece, one of which is new. If you want you can take two for 15$, that way you can assemble it without having to take off the struts you have on the car right now..... I can help with the bump stops as well... although they are kinda pricy so I would just reuse the stock ones if they are in decent shape.
87nasupra
Scotty's Garage
Mar 2, 2006
993
i got all new mounts , struts and springs for front and rear. the bump stops are in pretty good shape. planning on doing them tuesday. maybe tires tomorrow ? if your guy isnt too busy. need mount and balance is all. i got valve stems around here somewhere. lmk when your avalible to help me with those exhaust nuts....2 of the damn things are on but wont tighen the pipe up. i work off university if you wanna swing by after work one day.
87nasupra
Scotty's Garage
Mar 2, 2006
993
damnitt man !!!!!!! i looked at my front springs/struts and i saw something fuking wierd.....the springs are sitting sidewayz on the top mount....its like theres nothing to keep them sitting straight. the springs are sitting in he bottom of the bolts for the chassis mount.....Whats up with that ? !
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
SIDEWAYS?????? I thought you said you bought new mounts......(I just got your message from yesterday....... i didn't even know you called until now. Sorry about that, they had me running like a damn jackrabbit around here)
87nasupra
Scotty's Garage
Mar 2, 2006
993
yes sideways. you should see them man....they arent right. You gonna go to BJ's tonight ? if so ill bring them with me and you can see what im talking about.And bring the antenna, ill get that from you tonight.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Scotty check that one with the rubber.. It looks like the spring is upside down.. I think on Mine and Val's the spring went over that rubber piece. The spring should have a flat side and that goes on top.. Just didn't remember from looking at it last night..
