Hood Vent
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Painted it today, first layer. Still have lots more sanding/painting to do. It fits perfectly in the cowl over the high pressure zone. I also plan to extend my custom undercover further back for even less lift and even more downforce.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
tissimo said:
dont you have a carbon fiber hood? or that just temporary?
Yes its carbon fiber.
I got the vent from ShineAuto. It's meant for an fc rx7 hood that he makes. I had to remove 9 and 1/2 inches from the vent so I could fit it in the cowl with the opening centered over the high pressure zone.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
tissimo said:
so you're going to install this in your carbon fiber hood?
Yes
I already have a vent installed over the turbos
I don't drive the car in the rain
masterchief819 said:
Nooo, your car is too pretty to start tearing up the hood!
Lol thanks. It should look good so don't worry :icon_bigg
Grimsta
1,081
Santa Rosa, Ca.
AGlobalThreat said:
No, the low pressure zone is at the base of the windshield. The high pressure zone is over the radiator.
Yes, that is why in cowl induction air would get sucked in at the base of the windshield, giving us the NASCAR effect and ramming all that air into our carburetors. Wait a minute...
I was plannin on picking up a vented hood to evacuate hot air, a Chaser aerodynamics FRP hood, it weighs 18lbs and has a vent identical to that! I would get that vent, but i want to replace the whole hood with something lighter
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
I was pretty sure the base of your windshield was high pressure.. lol, hence why cowl hoods work so good on older muscle cars w/ air cleaners right their
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Base of your windshield is low pressure. Low pressure will suck in air.
Duane said the heaviest CF hood he made was 14 lbs :naughty:
Lots of people have their low/high pressures mixed up. An obvious giveaway is a shimmed hood on a supra ;)
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
i was gonna say, it makes sense for it to be high pressure, because the way the air flows over the car, it puts pressure on the base of the windshield, and since under your hood is low pressure, high goes to low and air is shoved in their... ?
WA
pressure is measured on the outside surface of the hood/car. nose of car is high pressure. most of hood is low pressure. base of windshield is high pressure. airflow goes from relative high pressure (inside engine compartment) through the vent to low pressure (outside hood).
its not rocket science.
