Mines not on, and I don't know how it bolts up, but you may want to put an extra wide washer on each mounting point to keep the bolt from stressing the plastic too much as this is where I've seen some start to crack.
87soup said:What vaccum line did you tap into for the BOV???
How did you mount the valve to the pipe???
starscream5000 said:The stock BOV vacuum source.
An HKS BOV flange.
What other direction would you point it if you're recirculating it?MK3.0dudeman said:why is it pointing down??and I know the hood wasn't hitting it.ask me how i know
