Has anyone used a hks beaded headgasket its $249.00 i was just wondering if its worth the money?Or is it just basically a MHG.
IJ. said:Mike: If I'm understanding this correctly the Stopper is an MLS like a Cometic?
And the Bead type is a single layer with rolled beads?
What is the Grommet HKS Gasket?
IJ. said:Thanks Mike!
Great info as usual.
Do they do a range of thicknesses?
Boss302 said:can u reuse a mhg?
Supracentral;216396 said:The easiest way is to look at the cross section of each gasket to see how it it makes it's seal
We'll start from least expensive to most expensive, and I'll throw my $.02 on each of them.
Bead Type:
As you can see, the bead type is exactly what it sounds like. A bead is run around each combustion chamber. It's a good gasket for most street cars, and can handle a considerable amount of boost when properly torqued.
Grommet Type:
As you can see, the grommet type gasket is actually a bead gasket with an extra "ring" around each cylinder. If you are going to spend the money on this gasket, I'd take the extra step and go right to the stopper type below.
Stopper Type:
This is the ultimate HKS gasket. As you can see by the design, it's a bead type gasket, and a grommet type gasket with the addition of the stopper being an integral part of one of the gasket layers. This is a very complex gasket to manufacture, however if you ever blow this gasket, you are REALLY doing something wrong. I've never seen one of these blow when installed with ARP studs and a properly torqued head. It's a monster of a gasket (with a monster price tag). However if you want to put the head on once, and run silly amounts of boost, this is the best gasket you can get.
