See if the whistle insert is melted if so dimantle your bov and check the small plastic 1 way valve inside the diafram housing. If heat is an issue or it is mounted above your turbo your hks bov is dead. V.2 & V.3 don't like heat.
toytech;1712196 said:See if the whistle insert is melted if so dimantle your bov and check the small plastic 1 way valve inside the diafram housing. If heat is an issue or it is mounted above your turbo your hks bov is dead. V.2 & V.3 don't like heat.
hvyman;1712451 said:Or put the heat shields back on.
