JDub's right on the money, the 3/8's deep 14mm 12 pt with a 3/8 to 1/2 adapter works great.
Or buy the right 14mm deep socket 12 pt in 1/2 inch, and your even better.
When you pull the head, see if you can pull the studs out first, prior to pulling the head. (They have allen heads in them.. I've found that easy out's work better to remove them than the allen wrench.. Especially if someone decided to loctite them into the block..)
I've re-used my Greddy MHG a few times now.. On 4 motors, and the orginal MHG job, so 5 times now...
Use brake cleaner, and it removes all the rubber/viton on the HKS MHG. Then put the gasket between your tourqe plate, and the block when they cut your bores, and it's the right size bore too... Clean it up with brake cleaner again, blow dry with compressed air, and then I've found using brake quiet spray on both sides works great to seal up the gasket.
Key is this. Coat it with a few light coats untill you get a nice thick coating of the brake quiet on both sides.
Your engine should have the front cover on, and be ready for the gasket and head. Don't put in the studs yet.
Take some form-a-gasket, or "The Right Stuff" and put two small beads down on the block between the front cover and the block. (As per the TSRM.) and then very carefully, lay the coated MHG into place WITHOUT SLIDING IT AROUND. You want to drop it onto the pins and it's done.
Now, with a friend helping you keep the head steady, place it straight down over the gasket and onto the alignment pins too. NO sliding it around. (IF you do, pull it all off, clean it all up, and coat the gasket again.. and start over..)
Ok, now comes the time for you to use those head studs! They work great to align the washers into your head.. You lube up the ends with moly grease, and both sides of the washers, and then slip the washers down the studs as you put them into each hole.. (Otherwise, you are going to find, the washers DO NOT FIT down easy, so you have to pull the F'n studs anyway to get the washers into place..
Do it my way, and save yourself the curses I've had to invent when I loctited the studs into my head, and then found out the washers don't fit... and found out that easyout's are the easy way to removed stubborn head studs...
Ok, once your washers and studs are in place, and you have the nuts lubed up and on the studs, follow the TSRM pattern, and tourqe the head down in a few passes to about 95lbs (This seals up the head and head gasket with the still uncured brake quiet, and you will have zero leaks in my experiance.)
Good luck, and enjoy.
