Help removing power steering belt
caballo
78
So Cal
AJ'S 88NA
2,419
Florida
It's the big bolt #590 that you have to loosen from the back side of the pump. And the adjustment bolt on the front.
caballo
78
So Cal
I removed those two bolts already. The pump did have some slight foreplay after removing them, but not enough to remove the belt. I noticed that the pump is hanging on from two 14mm bolts that are attached to the block. I removed one of the bolts, but the other im having a really hard time unbolting. lol
