So, with blue smoke on start up, excessive blow by, and corrosion in my current (JDM) engine, I've decided to do a complete rebuild - my first - on what's left of the original engine with ~180,000 miles on it this winter.
The block looks great, including the bore, but the head's shot and warped 120 thou. I've got most of the rest of the long block, though, including mani's, TB, etc. I also have a NIB water pump ready to go on.
As for my goals, you can see my current mods list in my sig. Over the next couple of years, I would like to upgrade my catback, 550's/Lex, Walbro, and AFP. Well tuned, I think I would be able to make about 400 whp give or take, and I'm more than happy with that.
Well, I started pricing things out and I'm a little discouraged. So far I know my list looks something like this:
So that's a good start on the major items, and some of the prices are as I remember them but close. Adding up what I think I already know I will spend, I'm already topping $1,200 and that doesn't include any work at the machine shop on my block.
BIG QUESTION #1: What are the essential machining operations that need to be done and how much? Balance/polish the crank and machine the deck for MHG for sure, right? What else absolutely has to get done? What is nice, but can be left out?
BIG QUESTION #2: Any comments on making my dollars go further on my list of things to buy? I.E., would an HKS MHG for $100 be just as good, and what about the oil pump? Did I miss anything major (I know there will be a bunch of miscellaneous things like belt tensioner, etc)? Any recommendations on where to get the best price on some items, or things that are okay to buy used?
Of course it would be great to go with forged internals and spend a few thousand dollars more, but I have to be realistic here and remember my goals are pretty reasonable, so stock pistons & rods it is. Hell, if I make 300 to 350 dependable HP I'd be happy with that.
For now my goals are simple: Good, solid and dependable rebuild for minimal money without cutting important corners. Let me know what you think.
- Cometic MHG - $170
- JE Rings - $150
- ARP Head Studs - $125
- OEM Oil Pump - $240 (Aisin on Ebay is half that - please discuss!)
- Clevite 77 Main & Rod Bearings - $100
- Fan Clutch and Blade - $50 from SM member TBD
- OEM Timing Belt - $50
- Rebuildable GTE Head - $75 - $100 or $350 for recent rebuild from classifieds
- Head Work - $300 at machine shop if I buy one to rebuild
- Block Work - $?????
