Well, everyday I get closer to finishing this swap, but I'm having trouble locating some of the connections. Below is where I'm having trouble.
![sm_photo_missing.jpg](https://www.supramania.com/images/sm_photo_missing.jpg?old=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv158%2Fimproved%2FIMG_0017.jpg)
![sm_photo_missing.jpg](https://www.supramania.com/images/sm_photo_missing.jpg?old=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv158%2Fimproved%2FIMG_0013.jpg)
![sm_photo_missing.jpg](https://www.supramania.com/images/sm_photo_missing.jpg?old=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv158%2Fimproved%2FIMG_0014.jpg)
Bigzavs;1139835 said:third pic looks like t/c compressor
cant tell the second pic connectors
improved;1141300 said:Do you know if there is any way of hardwiring the PPS to the car?
Matt-
suprastanger507mgte;1141306 said:The PPS plug should be hangin on the alternator side ( passenger dies )from the 1JZ harness. You will need to extend this plug to reach the the soenoid on the power steering rack located on the Drivers side.
suprastanger507mgte;1141481 said:ON the passenger side for a right hand drive car.
YOu can just run two wires straight from the M1 Dash plug to the solenoid plug on the steering rack.
Evilempire1.3JZ-GTE;1141245 said:3rd picture is jb#2 connector it haves your alternator wires.
the small connector in this picture goes to the water temp sensor (bottom left of radiator) for the hydrofan ecu.
Evilempire1.3JZ-GTE;1142446 said:You dont need PPS if your car did not come with it factory on the body. It actualy gets in the way if your car didnt have PPS on the rack. You dont need to change your rack and add the controller and I would avoid it unless you need it or want to go through the trouble of adding things.
All it does is turn off the power steering when your car goes faster speeds so you could get a little more road feedback.
The older supras or non equiped with PPS use a stabalizer strut and power steering on these just turns on the hydrolic assist as you turn your steering wheel.
improved;1142521 said:Where is the M1 Dash Plug? Do you have a picture or location? Does anyone else?
Matt-
suprastanger507mgte;1142635 said:Sorry, its not the M1 connector, its the B3 connector .
IF you have a 89 + Supra, this will be a dark grey plug near all the other body plugs close to the ecu area -
It has 10 pins .
Pin # 10 = White/Green (connects to same color on PPS Solenoid connector)
Pin # 4 = White/Red (connects to same color on PPS Solenoid connector)
Just look for these two colored wires on the connectors on your harness and you will find it. There are a few empty spots on this plug as well.
Hope this helps.
Moe
improved;1142720 said:Are you sure it's a 10 pin connector? Anyhow, I see a 10 pin connector with the white green and white red wires. But the wires coming from the rack are red/blue and red/black. Which goes to which?
Matt-
