Well, I would still test your BPV, as I've seen many bad ones. Ironically I still have mine, and it functions properly. Take the BPV off and try to blow through it, if you can it's toasted.
The valve on top of the Tstat housing? Its storming now so Ill have to check it tommorow.1988SupraDreams said:Well, I would still test your BPV, as I've seen many bad ones. Ironically I still have mine, and it functions properly. Take the BPV off and try to blow through it, if you can it's toasted.
Well, the 34 code just came about after I put washers behing the wastegate about an hour ago. ON the BPV you wouldnt happen to have a pic of the location would you? Ive taken the 3000pipe off numerous times and cant recall anything hose connecting to it.1988SupraDreams said:A bad BPV is the worst Boost leak you can have next to a blown off IC pipe. Check that thing. It comes off of the intake and goes into the 3000 Pipe, that's ur Bypass Valve. Shouldnt throw that code unless you have a major boost leak or are pusing an insane amount of boost with a boost controller. My bet is on the BPV being the cause of your code 34.
*NM* Its the BOV or basically right?Burntz said:Ooh yea i forgot about the blowoff / bypass. If its not holding boost for you = boost leak.
Z'mnypit said:*NM* Its the BOV or basically right?
Idealsupra said:yes
but the code 34 is simply "fuel cut" nothing you "do" will clear that code....you need to just set your boost lower then fuel cut...thats all. so yes deshimming it a bit should fix it.
fix the KS the right way and clear the code 52 and i promise your problems will be solved
Burntz said:agreed
+1
corret me if I'm wrong, but if you knock sensor is bad, and telling your ECU that you are getting a shit ton of knock ,then the ecu would retard the timing considerably to avoid that right? and it would make your car run like ass.
Idealsupra said:yes
Burntz said:corret me if I'm wrong, but if you knock sensor is bad, and telling your ECU that you are getting a shit ton of knock ,then the ecu would retard the timing considerably to avoid that right? and it would make your car run like ass.
Well I knew that but the knock sensors serve the same purposestarscream5000 said:LS1 vs 7M-GTE... Very different bud
