Hello fellow coolant burners,
Recently, i blew a head gasket beating on my car during the last 100 miles of a 350 mile road trip. Didn't realize I was blowing smoke until i hit city lights, and as far as i can tell, i "only" drove the car about 20 miles after i knew i had a problem. The car has been parked and is currently back home in KY, where I was leaving it for the winter. (I live in Cleveland OH.)
I'm one of these types that isn't going to have the time to pull the block and have it machined while I'm at home fixing it over break. Assuming it isn't noticeably in need of machining, I do not plan on having the block decked. I was planning on running a MHG, but it appears that would be a terrible decision, given my chosen course of action here.. I DO have a stock HG I bought from the dealership lying around. So now it appears that I may be able to use it.. the thing that sucks here is the fact that I'm going to have the head machined down most likely.
Does the use of a composite stock gasket help my cause in terms of tolerance for HG thickness? (since they're more likely to seal with a non-machined block surface?) I'm assuming compression ratio is a completely independent consideration and will ultimately be affected by the machining of the head, regardless of HG material.. Therefore I'm going to have to get a thicker Composite Gasket. Right? Rendering the Toyota gasket useless for my application?
I'll be returning home with the intent of fixing the car with haste in about a month, so whatever I need to order, I need to order it now. How do you guys recommend I handle the situation, since I won't be machining the block? Most of this thread addresses MHG issues, but there's not much here regarding the use of Composites.
As always, excuse my ignorance please.
Aaron
