Ok i am not familiar with rebuilding foreign engines (knowledable of american) Anyways i have a spare block and head that i am planning on rebuilding, not as a daily driver. I plan to build it from the bottom up inside and out. I have two mhg's one is the hks 1.2 and the other i believe is a 1.5, I know it would be a big jump to pull the rivets and make a 2.7 mhg, which would lower compression alot, but is it possible? Given i machine the block and head for use of an mhg? I plan to use bigger cams, and higher compression pistons.
I would go stand alone and upgrade fuel and air as necessary. Mind you this is only thoughts right now. just wanna know if it is is something that can actually be accomplished? any and all thoughts would be helpful.
I know by, if possible using this gasket set up i am gonna run into cam issues along with timing belt lengths and all that good stuff, but it will be done right if it can be.
