Hard to start, leaks gas like crazy!
billspreston01
555
North Carolina
most autozone's or advanced auto's can have gaskets like that next day if you order them (some might take more time)
On the other question:
I don't know how much you should take apart. I would advise spending more time trying to find the leak. If there's that much fuel you should be able to find it
supraGhost
212
PA
thats the problem. there is so much fuel i can tell what area it is comign from but not exactly what. if i can get my throttle body off, i think i will be able to get a better look.
supraGhost
212
PA
alright so i finally got time to get into this....
i pulled the throttle body and the 3000 pipe off. it looks like the 3rd injector from the front is leaking badly around where it enters the motor. so im guessing its just a bad o-ring. i have some extra injectors laying around, could i put one of those in, or should i buy new o-rings or what?
also, and more importantly, to get this injector out, what do i have to take off the motor? do i have to take the intake manifold off? cause that looks like it is gonna be a pain in the butt.
thanks
jdub
Feb 10, 2006
10,730
Valley of the Sun
You should be able to remove the fuel rail with the upper intake manifold attached:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=84
I would get a full set of O-rings for the rail and grommets for the head. It would also be a good time to clean the ISCV and inspect/replace the check valve under it. You will also need new TB & ISCV gaskets, and crush washers for the fuel line attachments to the rail.
mista_sup
211
atlanta
you can i just did it two days ago. i recomed you change all of them the ones in the head, the ones on the top and the ones in the middle. at napa you can get a injector kit for about two bucks each and it includes all three rings.
i tried to use an old one and it busted on me and i had to go back in so i just did all of them the second time now its good.
ps.. when you install them get some grease and put just a tad around the top of them before you install them into the fuel rail. onse thats done you should be good...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Vaseline works well ;)
Mk3runner
2,033
Nor Cal
oh noes, vaseline is kinda rough there!
jk, but on subject like the other guys were saying its not that hard just gotta remove some crap to get to it. when I did mine it was when I was building my motor so it was easy for me. but still the same for you just in the car. this way you can look for other stuff wrong while your in there.
best of luck with it, remember to take pics.
supraGhost
212
PA
im marking everything with painters tape:biglaugh: and numbers so i remember where it all hooks up.
its going pretty good, but im stuck. i cant seem to get the bolt that connects the cold start injector tube to the fuel rail loose. it is super tight.
also, how do i clean the iscv?
supraGhost
212
PA
nevermind about that bolt. i jsut got a bigger ratchet:)
so i finally got my fuel rail off and the injectors out.... but two of them left their o-rings in the head and i dont know how to get them out. i thought about prying them out with a screwdriver:aigo: but i didnt want to screw anythign up. whats a good way to get these out?
jdub
Feb 10, 2006
10,730
Valley of the Sun
To clean the ISCV you have to take it apart. Three screws hold it to the base, remove them and the motor will come off. Be careful there's a thin hard rubber gasket under the motor...save this. Clean the aluminum housing with brake cleaner and a brush...same for the plunger on the motor. Then just reassemble...it will only go together one way. Make sure the check valve under it is facing the correct direction and use a new gasket when you bolt it back on the manifold.
Use a piece of stiff wire with a small 90 deg bend on the end. Hook the grommet and it should come out. Check all the holes in the head for rubber pieces...sounds like yours were pretty hard.
supraGhost
212
PA
ok i am going to order parts but i dont want to forget anything. i need:
injector o-rings and gaskets (6)
TB gasket
iscv gasket
and where are these copper crush washers you guys are talking about? i found three copper washers on top of the fuel rail but they look solid, not like crush washers. and are they vehicle specific or jsut generic washers?
anything else?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Easy there, before I start thinking you're related to SpaceGhost. The parts you mentioned should be all you need. Get the crush washers at the dealer and don't be surprised if they turn out to be aluminum. Truth is the copper ones can be reused if annealed but that's advanced stuff and I wouldn't want to hear you set yourself or the car afire. Might also be a good time to change the small hoses on the TB and ISCV if they're old and you still have them.
supraGhost
212
PA
my o-ring rebuild kit for my injectors came with 4 o-rings. three of them i know where they go but there is one larger thin one that i have no idea where to put it. any ideas?
supraGhost
212
PA
ok i still dont know what that 4th o-ring was used for, but i put it back together and that fixed the leak! so thanks guys.
now my waterpump is leaking:3d_frown:
/thread
jdub
Feb 10, 2006
10,730
Valley of the Sun
Might be for the ISCV...between the motor and the housing.
Post a pic.
