Gurley's 92 Teal 2JZ Project
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Albert;1786726 said:
I hear that every time people see my engine bay..... Followed by "why not a 2jz brah?"
Funny how both of you guys own 2j's............................................................................................................................................
Ya good idea I dont want any Andys creeping around in my valve covers, he might break my camshaft, oh wait its BC not a fragile HKS :sarcasm:
IBoughtASupra
4,455
Queens, NY
-__-
Low Blow!
Welded>Tapped, Hold on, my welding owns tapped, your welding looks like Dustin's bird shit. LOL!!!
Both of us need 2JZ when we feel like there is no real need for power, you know, a cruiser.
Albert
May 13, 2009
1,710
Tempe, AZ
Tapped gives you chances to change out fittings, if you go with a bigger turbo, and your hose is in the way, put a 90 degree fitting on. Can't do anything after its welded and powdercoated. Newb
IBoughtASupra
4,455
Queens, NY
-_-
Why in the world would you need bigger than -8AN lines for a catch can setup on our motors? 3.4 2JZ with a 80MM on it and it is running only a -8AN line with my catch can. Not a single bit of blow by and it is not vented either, vacuum assisted. I assure you, -8 is more than enough. If you need more than that, someone has a shit load of blow by and something needs attending too. :-/
Lastly, WTF would you weld a 90? Just put a male straight the 90 AN fittings.
Albert
May 13, 2009
1,710
Tempe, AZ
Weld your subframe to your frame, and weld your motor to your subframe then.
there is a reason God Created hardware. =P
Albert
May 13, 2009
1,710
Tempe, AZ
