Group A's group a rebuild
SupraMario
I think it was the google
The Farm
I wish u luck tonight, you'll get it. everything takes adjustment and tinkering, even if it says plug and play. LOL
Steve: When I did the 4>1 Collector for the Datto I made a press tool that was 4 tapered pieces of bar welded together, I then put it all in the press heated the tube and pressed away.
group a supra
SPAWNING AN INTERCEPTOR
tonight
decided to pull the old collector off and finish of the prep work ready for fabrication
i also have the shortest radius elbows ever for this manifold so should help.
I also included a photo showing how much bigger the 48.3mm is compared to the ss autochrome 43mm header
any thoughts anyone ;)
group a supra
today part one
getting a little tired of moving the exhaust flange around to be fair had it on and of the car at least 10 times today cuttin and weldin after i found that i could not clear the runners on the exhaust
in the end i arrived at a position i felt was adequate by a couple of mm and shaved one of them sticky out bits of alloy of the turbo housing just enough to get clearence.
and so it was then i started to make the runners out of wedges so that i can swap them with 90 degree bends after when i know how many i will need with out having to waste any
bonus of the day was the downpipe i made fits perfectly into the rest of the exhaust system and mates up to the turbo in its new position result at last i feel like i am getting a little bit closer to some sort of completion :)
