ground off ridges on valve covers
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
st2b;891883 said:
Could I do my 7m-ge valve covers the same way?
Just take a bench grinder to smooth the top surface flat and even, and sand for 100,000 hours?
7M-GE valve covers are grooves and not raised sections. You'd have to make the entire valve cover thinner to do it. Would take much more work.
Jeff
selfinfliction
434
ky
finally got them done
before:
after:
Ckanderson
2,644
The beach
Jeff
or you could fill it in....................
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
when welding the valve covers, you need to be careful. its cast aluminum, so there are some small voids, and they can warp if you heat them too much
