GrimJack's rebuild
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
dirgle is correct - though I found some issues with my knock sensor wiring, so I pulled off the plugs, fixed that up, covered it in heat shrink tubing, and put the plugs back on.
At the very least, it lets you put in some time inspecting the harness, so you'll know where faults may be and how hard they will be to replace later.
Dirgle
Conjurer of Boost
Pauma Valley, CA
When I did mine the entire harness was covered in electrical tape, which was a pain to remove all of it, clean the sticky gunk off it, and then rewrap it. I was wondering if you removed and replaced the tape or just stuck the wires back in to the new loom?
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Another relatively long night assembling the engine... with some NICE results. It is ready to go into the car, and hopefully this will happen tomorrow morning. A few things to hook up, a few things to bolt up, and I'm done.
Some more pics, of course...
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Engine is in the car!
Still have to hook up a bunch of wiring, fill the tranny & engine with fluids, and then she's good to go.
I'll post some more pics of the engine going in later tonight - as long as I can still type by then, of course! ;)
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Ok, now I am stinking tired. The car is close to running, but not quite. I still have to:
- mount the radiator
- mount and connect the fans
- run the rad hoses
- connect the heater hoses to the block
- connect the speedo cable to the tranny
- fix the clutch slave
- pull the wiring harness through the firewall
- hook up the ECU
- put the glovebox back together
- finish the shifter installation
- put the dash back together
- fill the engine with oil and coolant
- install the upper IC pipe
I'm tired enough that I started making silly mistakes, so it's time to call it quits for the day. Shouldn't take all that too long to get it up and running tomorrow, however.
Here's the promised pictures for the day.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Here is what it looked like immediately after dropping it down onto the engine mounts and removing the hoist.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
And last but not least, a few pictures showing how far it's come from there today. This is what she looks like in the driveway right now - except that the hood is closed, of course. ;) I'm done for the night, I'll likely finish up tomorrow.
PS: Anyone care to sell me a spare set of skin for my fingers? I think mine is done for.
shaeff
Kurt is FTMFW x2!!!!
11
Around
lookin' damn good, Grim! (sends spare finger waves via the intraweb)
-shaeff
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Doh! Stalled for the moment. Seems my water pump didn't survive the pressure in the cooling system induced by the BHG. :( It was almost all together - everything but the upper IC pipe and the accordian hose, and I decided to put coolant in... well, the water pump leaks, rather badly, out of the holes top and bottom.
Ckanderson
2,644
The beach
Weak! on the other hand... your writeup has convinced me to start working on my supra again.. workin on gettin the interior back togather today! Thanks!
