yankiwi said:Bigzavs,
The wires are MSD 7M-GE wires. They are longer than GTE ones obviously. They have the correct plug end and you have to modify the coilpack end to fit the GTE coilpack. The set I got came with that end unassembled. I cut to length then cut the brass electrode thingy in half, and squeezed it a little to reduce the diameter to snugly fit in the coilpack. Then cut the grey rubber boot, which starts out as a 90deg elbow. I cut it so it is straight, it then squeezes in the coilpack hole and makes a good weatherproof seal. I was concerned about the wires coming loose as I am not utilising the stock locking clip dealy, but they are on really tight. If you search for Bigaarons setup you can use one set of wires. With my setup the two shortest NA wires were just too short to reach my coilpack. Actually they did reach but it was too tight for my liking. I ended up with 2 sets of wires to make it work. I might move my coilpack down to where bigaarons is, then sell my spare set of NA wires.
I will try to get a pic to explain all the crap I just wrote.
EDIT to add pic
In order: My modified wire, the electrode before assembly/cutting, the boot before cutting, a stock NA wire
I did the same thing for my car with their 8.5mm wires and bought their minicrimper to put the ends on!
