bluemax said:Jeff,
How much performance would you gain in cams? I was under the impression that cams really won't get much more power. It just moves the power band around. For me, I'm planning on squeezing everything I can out of pump fuel. So cams would give me a little more. I'll be in the buy if the Forum needs more people. I just don't know what the best cam is for my application. May be someone can help me?
Adjuster said:I'm interested, but I belive you should also have HPF setup a shimless bucket option for the cams with more than 9mm of lift. (I belive that up to that point, and possibly 9.5mm it will not spit the shims, but over that amount, your running the risk of causing other damage to the head or entire motor.)
Either souce the bucketless shims from Japan off the Echo, or have them produced locally.
In any case, the market for this is going to be limited by the number of 7M's out there in any sort of modified state. (There are a few thousand, possibly 10,000 with mods to the point where these cams would be beneficial, but many of the "high end" customers are already there with custom shims, cams and other mods needed to benefit from the more radical setups.)
That being the case, I'd suggest if you don't want to offer the shims/springs and such as a kit, only build the cams that will work with the stock valve train gear.
My mods are 1mm OS valves and BBC inner springs. Both easy mods. (Especially the springs.)
A higher lift and slightly longer duration cam would be nice, and I'd be interested at the prices you indicate.
figgie said:well the ONLY issue with that is that they would have to keep stock of ALL the different sizes and the consumer would have to buy the cams. Test fit them and then order the correct shims. Eitherway they need a call back unfortunatly.![]()
ma71supraturbo said:We are actually thinking the same things here. I've been trying to source a used head so we can test the Supraforums rumor of some random domestic valve spring (read: cheap & readily available) fitting perfectly. Getting springs and retainers will probably be pretty easy....
drjonez said:SF rumor? try a SOGI "rumor". it's actually a fact, the comp cams springs work fine....several "old skool" guys have been using them for yrs....p/n is on mkiiitech.com....
BTW- if you guys need a head to test stuff on, LMK. i have like 4 and would be happy to ship you one....
siman said:Which buckets and springs work?
-Jonathan
siman said:http://www.powerandperformancenews.com/store/merchant.mvc?Screen=CTGY&Store_Code=CC&Category_Code=SPRNGSI
Comp cams has three different "975" part numbers.
960 INNER (RED)
Code: 975-1
Price: $2.61
None in your basket
960 INNER (RED)
Code: 975-12
Price: $31.33
None in your basket
960 INNER (RED)
Code: 975-16
Price: $41.78
None in your basket
I am guessing that that is a pack of 1 or 12 or 16 if my math skills serve me right..
-Jonathan
