FFS it's a radiator hose it has to hold 13psi..... :nono:
ONLY reason to go braided on a road car is appearance.
Zumtizzle;1469100 said:..... and Non Hose Damaging Worm Gear Clamps from Volvos.
IJ.;1469993 said:FFS it's a radiator hose it has to hold 13psi..... :nono:
If I really needed to upgrade I'd use braided stainless....
Poodles Samco will hold more pressure And they come in black
Didn't "miss" anything was just commenting on the fact that braided rad hoses are an expensive WOTM on a road car, last I checked you'd never ran a Turbo Supra fullstop.....gaboonviper85;1470263 said:maybe you missed that part?....Last i checked I'm not rocking braided lines...
Can't see how there would be a pressure spike on the t-stat opening Pete it's not like the system is divided until it opens, the bypass allows the water in the block to heat to the T-stat opening temp which when pressurised is well below boiling so if anything there would be a slight drop as the cooler rad water enters the block.wiseco7mgt;1470270 said:Ian , i was told by a radiator fabricator that the only time the cooling system sees any kinda high pressure is the sudden burst when the thermostat opens, Is this true?
At the time we discussing plastic end tanks becoming brittle although i'm sure the pressure varies widely according to different vehicles.
Poodles;1470348 said:If the bypass is clogged, the pressure can rise on the heater hoses (common problem on the early miatas)
