JetJock educated me on the advantages of CT clamps way back, until then I hadn't given them any thought and just replaced them with worm clamps routinely.
adampecush;1468815 said:..were factory clamps actually yellow...
jetjock;1468887 said:^Lies...all lies
It appears the "seasoned engineer" needs to learn more about zinc chromate...
adampecush;1468815 said:were factory clamps actually yellow? i know some of the spring clamps were (and still are) but I've never seen a yellow heater hose clamp.
gaboonviper85;1468809 said:Gates hose isn't silicone;-)
Poodles;1469103 said:If it's not silicone :/
jetjock;1468887 said:It appears the "seasoned engineer" needs to learn more about zinc chromate...
jetjock;1469105 said:edit: Iirc Gates hoses are EPDM. Made to resist ECD...
gaboonviper85;1469194 said:Not silicone....it's not cheap shit though! Just good quality gates racing hoses...beats paying $120 for a set of silicone hose...considering the stock Toyota hose lasted 20 years the gates hose should last just fine.
Gates racing hoses cost $60 for the set...good enough
jetjock;1469091 said:The factory constant tension band clamps on my car were green. Whether they were zinc chromated (which can be green) I don't know. I assume they were. All but one (the replacement was also green) were in service 22 years and not once did any of them leak.
gaboonviper85;1469636 said:Kevlar??? Gates racing never said they use Kevlar...why do people keep saying shit like this? Gates has glass cord running threw the belts to add strenth etc..
Any way...upper and lower rad hoses are probably $100 from Toyota...gates racing was $60....I'd rather go with gates thanks.
Zumtizzle;1469673 said:There was a vendor on here screaming that Kevlar and Angel Dust Makes the Gates Racing timing belt.
Toyota Rad Hoses are probably 100 from your local dealer.
I personally bought a Toyota Upper, and a Lower 5M Normal Gates hose.
Nice Loom Job BTW. Got any advice for the Firewall Grommet?
Poodles samco...
