Furious But Lazy 7M owner who gave Up.
Turbo Habanero
4,229
Tucson,AZ
Turbo Habanero
4,229
Tucson,AZ
I will get a video up today or atleast try
One thing that needs to change is the fan clutch setup. The ls400 fan clutch is on 100% of the time and loud as balls.
Anyone know of any other setup that will allow to run a 7mgte fan blade ?
Albert
May 13, 2009
1,710
Tempe, AZ
Nice Jordan,
So how fast is it?
Why not get the tune and turn it up?
Is you Iac recirced into the inlet too?
please do something about that hose from PCV to inlet
Turbo Habanero
4,229
Tucson,AZ
Albert;1914803 said:
Nice Jordan,
So how fast is it?
Its slow. But no big deal to me im just haply to have it.
I will take care of that hose asap just not sure how yet.
Tune and other things cost money so im back to saving and all in due time. WISH I had someone around her to help me try and clean it up a bit with the AEM until I can take it to UMS
Just go to a RC car shop and buy like 1k or 2k silicone diff fluid for the fan.
I put 3k in mine and its a little too much for me. Might work better for you since your in a hotter area.
Or you can switch to a 2jzgte fan clutch with 2jzge fan blade.
Albert
May 13, 2009
1,710
Tempe, AZ
Okay I got ya.
You should do custom bent lines that hug the motor to firewall and do a catch can.. Or do what I did on a fresh motor that has no blow by, put a filter on it
Albert
May 13, 2009
1,710
Tempe, AZ
Use a 2jzgte fan and 2jzgte clutch, I used 2k silicone and its amazing, fits the oem shroud too
87supraguy
808
Tucson, az
Albert;1914807 said:
Okay I got ya.
what's with you and "custom bent lines"? lol
Turbo Habanero
4,229
Tucson,AZ
So the cars is running rich way rich
10.7-11 at idle and cruise.
So right now I turned down my fuel pressure too 25psi with no vac. Now the idle is around 13.5 haven't driven the car since the change.
Turbo Habanero
4,229
Tucson,AZ
BoostMonger;1914855 said:
Just made sure it's safe to boost it, get that bad boy dialed in ;)
Sent From My HTC One S using Tapatalk 2
Yeah as long as its not lean under boost I should be okay.
Since its only at 6psi I doubt it will be. :)
