fuel tank removal Walbro install...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
Justin727 said:
yes in the hatch there are cover plates u unscrew and pulg wires u disconnect.
lol shaeff I as well!!
your talkin about that little access door inside the hatch? I'll look there today when I get out there to get to work...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
Justin727 said:
yep. that door. then ur fuel tank straps, fuel lines, and plastic piece in the fuel tank door for the filler. slowly let it down with a jack.
yeah I tried to take that plastic part off by the cap and it wouldn't budge and I didnt want to break it... plus I'm doing this on the ground... is there enough clearance to pull the tank with the filler neck on, on the ground?
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
Justin727 said:
no you need to jack the car up and put it on jack stands. after if you get ur jack and push up on the tank some that plastic piece should come loose.
sweet I'll try that today... I just didn't want to try to pry it off and break it...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
well I just finished my fuel pump a few hours ago and it went smooth as hell... I probably could have done it a lot faster had I known what I know now... it's a piece of cake...
EDIT: oh yeah I forgot to say thanx for all the help from you guys...
