Fubar my 1992 supra turbo....damnit
N
NDBoost
Guest
gixxer750 said:
Factory pressure is a long way from zero at idle.... both my 88 turbo and my 86.5 na have over 20 at idle....
according to TSRM spec 4.3psi on warm idle is the minimum pressure for our motors.
max is at 3k RPM 36-71psi
although i dont really like seeing my OP at 4.3PSI i do agree most of our vehicles on good oil on warm idle will run 10-20psi.
92turbo4life
1,289
wherever
no mine doesnt it has to be a ho:)^
lol but im going to do the check and if it stops ill be rebuiling and if it doesnt it isnt a big problem. it will be somethin else
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
92turbo4life said:
well everyone i have achieved rod knock. or i think..
But have you achieved a third grade grammar level? I didn't read much farther than that because it was giving me a headache, put a little effort into it.
I'd take 47 or 52, because I'm not that picky. I love the '92's, but I'm also loving my '91.
Good luck Adam. Hope it's not anything TOOOO major.....lol
supra90turbo
shaeff is FTMFW!
32
MA, 01440
jimi87-t said:
If you were 4 qts low, you have knock.
:werd:
92turbo4life said:
52 please
i got 47 and shane is 88
woop woop under 100
tealmetallic dream and me are pimmps
Dude, I already told you, I saw your vin, and it's #52.
Prove that it's #47. Prove it. Seriously. Prove it.
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
I think you should drain the oil to find out how much oil is in the motor/shavings and then re-change the oil and then take a stethescope or hose and search for the noise. Then maybe tighten the exhaust manifold studs and valve covers because it could be the head clicking. I think you overfilled the motor with oil and you have something wrong with your head and not rod knock.
Geoff
N
NDBoost
Guest
werd whats so bad about a 52? lol
