front lip
dumbo
1,911
Albera, Too Far North
what is it for??
i figure maybe to keep dirt out of the engine bay?
might replace it, wanna remove it all together. any thoughts??
mine is cracked and all bowed out.
SupraMario
I think it was the google
The Farm
Looks, and so you don't scrape the fuck out of your real bumper...I think thats about it. Most people don't have one, or they just get an after market one. Trying to find a lip that isn't fucked all to hell is pretty hard.
ERA
1,934
any way the wind blows
I had a straight lip once.
Realized how awesome I was when I saw other Supras with the stock original lip.
Another member on here has it now though.
Stock bumper without the front lip looks naked and that is missing.
Went aftermarket, was too low. (H&R springs as it is)
As of right now, GRacer :)
dumbo
1,911
think i'll pop it off tomorrow, for a bit, see what i think:icon_bigg
seems like it qould keep dirt down a bit, but i'll give it a trial run without.
edit: yah i need some fog lights( thats right both are cracked) want led, but gonna order regulars tommorow.
aerodynamics and looks...
Also, if your lip is warped is more than likely because the bar it mount to is warped to hell. Gotta remove it and straighten it (not easy to get it perfectly straight). Then the lip needs to be unwarped (careful use of a heatgun works).
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Never had a lip for mine. I keep thinking that as ghetto as my car is already I'll just add a vinyl cove base lip.
How on Earth would a lip reduce dirt in the engine bay?
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
It helps to lower drag by limiting air underneath the car and by deflecting air around the tires.
It doesn't really do all that much but it's definitely better to have one than to have a big gap from your bumper to the ground, which will introduce more drag from the front tires.
iMod
136
Centralia/Chehalis
I found a write up that Facime did when I had my last Supra. He made his own front lip out of a few home depot materials. It turned out pretty good. Just search Bumper Home Depot Fix.
dumbo
1,911
how would a eninge undercover help in cooling?!?!??!?! i got one, makes no sense.
gonna check the bar it mounts to, hope it aint warped, but your prolly right:icon_mad: tell you in a while(few days atleast, start shift tomorrow:(
