got her back to life, Again i pulled the motor out to change the turbo and tranny.
My current complete drivetrain only setup
Stock rebuilt 7mgte, (Head and block was decked, but still on stock size hg, slightly higher compression than stock, new bearings, new rings, new gaskets, thats it)
Stock hg, Arp studs
57trim ct26
Driftmoution ct26 soft line kit.
Lexus Afm
S-afc
Aem wideband
Hallman Manual Boost Controller
3" Bic Divorced Downpipe
Full 3" exhaust no cats or resonators
2.5" Intercooler hardpipes with hks ssqv, still on stock intercooler.
R154, stock flywheel, Action PP, Stock clutch Disk.
Still have some more minor stuff to do before i can take her around the block back under her own power, like change the oil, trq down the motor mounts, wire up reverse and the afc again, and finish installing the shifter.
I should be driven her in the next couple of hrs to make sure that this r154 tranny is good.
Then tomorow its time for some street pulls to adjust the fuel ratio with the s-afc.
When the weather gets a little bit warmer, i will install the walbro because i kno the factory pump is gonna take a crap on me soon.
Also next on my list is aeromotive fuel pressure regulator, then a set of 550's. Then its time to make it look pretty again. Power wise this should tie me over while i start building up a next block, with a mhg, and forged pistons.
