I am looking to get some insight from folks that went 1.5JZ using a GE Block with the stock NA pistons. While I know the stock NA/GE pistons are probably not the best option I believe it has been done and should hold my setup together, If nothing else at-least long enough to get the EMS tune perfect rather than tuning on a new forged motor.
Here are my questions
1.Using GE Pistons and a 1JZ Head what Headgasket did you folks use and what compression ratio did it yield?
2. What oil pump was used? The NA or the TT? I am told the 1jz and the 2jz TT pumps are the same? I am curious as to what the oil pressure is if using a turbo pump with no oil squirters.
3. My 1jz was used in another car with only an alternator with some ghetto custom bracket are the NA 2JZ ac pump and power steering pump brackets and pumps interchangeable? I assume the TT power steering suction hose "fitting" will be needed to ditch the huge NA reservoir.
4. Can someone post some pics of the front of a 1jz with the accessories in place as I could not find a nice one.
Thanks In Advance for all the help
BJ
BJ
