First Time Drag FAIL at Sac Raceway. NEED ASSISTANCE
te72
Classifieds Moderator
6,611
7
WHYoming
If you can source a set of FD Rx7 stock wheels, they make for a good, cheap drag setup. They're light, but still 16's. As for tires, I have 275/40/17 Nitto NT05's on Mk4 9.5" wheels, and I'd love to see how they do out of the hole launching on boost. Trouble is, nearest track to me is over 100 miles away. For comparison's sake though, they're VERY sticky for a street tire, and I have yet to even chirp them really... Launching on boost would be a whole different story.
What you should take away from this though, is that you want as much grip as you need, but no more than necessary (for weight reasons). That, and Devin's a beast with the results to back up what he says, so I'd listen to him. ;)
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Or if you could get some Mk3 NA's rear wheels, theyre wide and are super light and they're 16's so you can get a meatier tire!
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
ok so I went to the track with my mk4's wrapped in khump ecsta v700's in 245/40/17's. I kept bogging! It was SUPER STICKY!!! i dumped the clutch at 4000rpm's and i got wheel hop. my fastest time was 13.9
this weekend, i will be swapping in a 4.10 NA LSD differential, removing my rear polyurethane subframe bushings, and removing my front sway bar when i go back to the track.
My best run....
r/t .170
60ft 2.367
330ft 6.096
1/8 9.147
mph 80.47
1000 11.727
1/4 13.919
mph 104.81
if i can drop that 60ft to like a 1.6-1.8, shouldn't i be in the 13.5 range?
Devin LeBlanc
1,830
Las Vegas NV.
With that trap speed and driver mod the car should be 12.8-13.0
---------- Post added at 01:45 AM ---------- Previous post was at 01:44 AM ----------
By the way I run with all my sway bars connected, stock suspension other than springs..
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
well once my boy emails me the video of the run, i will post it for everyone to see. i just cant get my launch correct for whatever reason. maybe i need to go to 4500-5000 rpm's? i dont know
te72
6,611
7
WHYoming
Well, for reference, I launched at 5500, and like it's been said, DO NOT dump your clutch. Watch this:
[video=youtube;n5rpFXdWtK4]http://www.youtube.com/watch?v=n5rpFXdWtK4[/video]
Not about drag racing, but it stresses the importance of being smooth with your inputs. If you're impatient, skip to about 6:30 or so, and you'll see what I'm getting at. Dumping a clutch really won't do you any favors unless you're dealing with a proper setup, i.e. slicks, progressively engaging clutch, etc... but for a street setup, you really need to get a better feel for your clutch. Dumping will nearly *always* result in bogging if you don't launch high enough, or tire spin and wheel hop if you launch too high. There might be a mid point that's perfect for your setup, but good luck finding it. You'll be better off letting off the clutch completely AFTER you're getting boost.
Devin LeBlanc
1,830
Las Vegas NV.
Thanks, That was meh, 1.7 60ft My other one was a 1.6 but I forgot to take the trans out of overdrive and it shifted way to early would have been a 12.5 run I think
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
Ok So I went to the track again. This time, a friend of mine let me his his NA mk4 wheels equipped with Mickey thompson ET streets. Here are the results.....
60ft 1.986
330ft 5.649
1/8th 8.722
mph 81.01
1000 11.3
1/4 13.497
mph 104.55
What do I need to get this down more?
