So I got a tube that says "102: For oil pans and camshaft housings".
Is this the right stuff for the headgasket?
Also $15 for 3.0 oz's...wtf?
That's what that is.Yellow 13 said:Everyone said use FIPG.
Good idea, dont use the cork, you should have plenty as long as you dont make the bead too thick. Also, make sure to run the bead around the inside of the bolt holes, so oil won't start seeping out of them.Yellow 13 said:I have a cork gasket that came with the toyota gasket set. Im not gonna use it though. Hopefully 3.0 oz's is enough to do the oil pan too. They said it was :dunno:
Yellow 13 said:What about fel-pro HGs? Mine ran for a couple minutes then I pulled it apart (Piston slap) and about a square inch sealed, maybe a 1/2 fingernail deep.
