The strakes are a great idea although you'd need more clearance. Directing to the brakes is good and also directing air around the tire.
You're basically describing a front air splitter. They're very functional and keep a lot of air from going underneath the car; You also need to have more clearance since the lowest part of your car will now be farther out.
I wouldn't recommend using any kind of plastic/lexan. I have tried both (3 with the plastic you described and 1 sheet of lexan) and all of them broke in some way in a matter of time.
