black89t;1368123 said:mine must be magic or something....:dunno::biglaugh:
The one in my 91 supra ran for over 3k miles, I guess mine too
bluepearl;1368425 said:To the best of my memory John Lunsford was running 18 lbs. of boost with a CT26 60 trim, LEX afm and 440 injectors without any type of fuel control.
I'm just want to increase the diameter of the piping so that air can get in and out easier, turn up the boost, and get it tuned. No fuel upgrades.
Kckazdude;1367854 said:If you are planning on running anything over stock boost I recommend using a MHG with proper block and head surface prep. Its a PITA job enough to do it once. The second time doing it is just a kick in the nuts for not doing it right. Then again, there are a few people that are doing some nice HP out there with a composite gasket. Then again they did the proper surface prep and proper tuning to get there.
When I googled info on supras and bhg's a long time ago to learn about it, a lot of pages promised that simply replacing the hg, resurfacing the head, and torquing it down wouldn't give you problems again. Also, the hg's seem to last ~80k miles (84k til hg blow on the 91, 89k on the 90 and still sealing...kinda) without the additional torque, so I figure that 11-12 psi would last a few years. But if the risk increases exponentially with increased boost, I'd like to know what those who are running composites did to get around this.
Zumtizzle;1367895 said:Okay okay,
Fail Pro is crap.
Only go with stone, ishino, or toyota.
The following pictures are of a Felpro installed about 800 miles ago. I installed it with ARP pro bolts and torqued to 80 ft/lbs. with ARP moly lube. Obviously, Felpro stock type gaskets just don't hold up. It should be noted that there were absolutely none of the usual signs of detonation.**
MHG isn't needed. Ask if he sells Beck-Arnely
Citation: **John B. Lunsford.
Kckazdude;1367178 said:I dont know what parts store he works at but they are full of shit. Rock and Ishino are both cheaper imported gaskets that are not close to the same quality as a Fel Pro or Victor Reinz.
so who's right?
