ok this one is going to be a big challenge..
i had a mechanic swap my 1jz in and apparently he didn't do a very good job.
i have some hydro fan problems, the fan runs on low speeds all the time. i found out that i never had a hydro fan ecu. i found this instead.
thats right.. thats the hydro fan ecu male connector and a female connector together. where is the hydro fan ecu!? and why are only pins 4 and 10 connected ? where do these wires lead? BACK INTO THE BODY HARNESS. :3d_frown: pin 4 is the oil press control valve, and pin 10 is the water temp sensor, but the thing is.. there is no water temp sensor wire plugged into the water temp sensor itself. so what is this mystery connector? i dont know, maybe one of you could help me out.
more pictures of the mystery connector
pins 4&10.. why?
hydro fan ecu plugged in
its not perfect yet, it plugs in nicely but im not sure it will work. no water temp sensor is plugged in, and i cant find the water temp sensor harness anywhere in sight ( does anyone know where it is?) what is going to happen to the mystery connector?
i have been looking around the threads and i see a lot of hydro fan ecus having this extention harness.
why? does this have anything to do with my mystery connector?
i need halp :cry:
![2655313454_b858ff73d7.jpg](http://farm4.static.flickr.com/3001/2655313454_b858ff73d7.jpg)
![2655313448_e52eabcd4c.jpg](http://farm3.static.flickr.com/2116/2655313448_e52eabcd4c.jpg)
pins 4&10.. why?
![2655313442_8542f25db2.jpg](http://farm4.static.flickr.com/3178/2655313442_8542f25db2.jpg)
![2655313444_94576a011d.jpg](http://farm4.static.flickr.com/3123/2655313444_94576a011d.jpg)
![2654499791_53b520e3ee_o.jpg](http://farm4.static.flickr.com/3032/2654499791_53b520e3ee_o.jpg)
i need halp :cry:
