Facts About MKIII Brembo Rotors
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
The holes and slots create stress concentrations in the part.
If the rotor was not designed originally with these holes in mind, then chances are the stress in those area is not safe and will indeed fail in those areas. Especially if the holes are close together and or near the edges of the surface.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well of cores this will happen but if you use a good casted part there will not be a prob to certon dagree
there is alot of tecnogy going into casting
piaa for example they use low perure casting with there cast wheels
casting has come along way since the 80's causeing now you can have nice grain to it and more even though out the steel
look up casting and sucg that shit has come along way
now for the big thing on muching in slots and drilling
the key si to use a good sharpe bit and cold cut aka no over heating
kvr use great methed on cutting there rotors perures air cooling instead of cutting fuild wich works but doe snot as good as air
air cooling takes longer but is way better then cooling then cuttign fulid
in the end if doen right it will last for along time and work great
but any thgin form china stay the fuck away
SP 7M
Use your GUY instinct
Apr 6, 2005
274
Oceanside (for now), CA
Man. All I can say is you better hope the Grammar/Spelling Police don't come across this post! You're going downtown if you get caught.
SySt
Burnsville, Minnesota
Thats just Nash, he always has grammar like that. Kinda funny though how people don't need to have good grammar but you can still be able to tell exactly what words they were trying to type.
BTW I would say the best way to cut the holes is with high pressure water. Little if any heat generation and very precise.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
what about plasma cutting? would that generate too much heat/stress?
QWIKSTRIKE said:
That wasn't very nice...Nash may be dyslexic but he isn't an ass like you. You havent been around long but grow up to respect the problems of others. He is a very smart idividual. Wzup Nash!
Respectfullly put as possible
Anthony
edit:
my apologies. i did overstep my boundaries, please e-slap me if it happens again.
nash, my fault, bad grammar/spelling is just a pet peeve of mine; ill find an un-assish way to get it across next time
clip
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yes water jet is one nice thing to use we have one here but ours has some issues cuttign thin gauge mealt but i think mike will a fiur it out or replace some stuff
ps water jest are freaking messy
air cooling the best but it's harded on bits a then water/cuttign fulid cause it just boils and does cool but not as much as air
