jgcable;1216084 said:How do I activate it?
I notice there are 2 switches in the door jams. One is a plunger type and that controls the inside dome lights. The other is a lever type switch that appears to be broken on the drivers side. It looks like there is supposed to be a plastic piece that sticks out and moves when the door hits it. That plastic piece is broken off. Is that part of the alarm?
jetjock;1216360 said:The stock alarm isn't complicated once understood. The problem in doing so is Toyota's poor description of how it works. The switch designations in the EWD are confusing but at least they're better than the 87 model year's documentation. There the pin numbers are wrong and entire parts of the circuit are missing. Because of that I had to physically analyze the system way back when there was no newer EWD to consult. Now that I've dug those notes out I'll have to retract my comment about gelboy being right. The door plunger switches are not connected to the theft system in any way. They're strictly for interior illumination.
CJ: Arming the system without using the key is done not by the solenoid switches but by the latch switches designated "door lock sw" in the EWD. These switches involve the latch mechanism, the part that engages the door striker pin. When the system sees the solenoid switches (door locks engaged) open *and* the latch switches open it will arm. The change involving holding the handle up is mechanical. Both systems electrically operate the same way. In the Service Hints section, when dealing with pin 7, the terms "door open" and "door closed" should be replaced with "door unlatched" and "door latched". It's this kind of thing that makes the system confusing to understand unless the wring has actually been rung out the way I was forced to do years ago.
On my car reaching through an open window and using either the solenoids or manually pulling the lever will result in triggering. There are also simple mods that can be done to the factory alarm wiring to improve it's effectiveness. For example the starter interlock can be put to better use since fuel control is located in the same junction block. Anyway, rather than explain the entire system here I'll do a write up on MKIII tech when I get some time.
cjsupra90;1216395 said:Ah, ok that makes sence... I wonder why mine acted the way that it did... Hmm ohwell I guess it doesn't matter to much being that its no longer there...
I agree, fuel cut insted of starter cut is a much better way to work the system. For those wondering why, well this is especially true if your car is manual. You dont need the starter to start the car... Push, dump the clutch and drive away... I had a RX-7 years ago that was stolen like that.. Ever since then every alarm I've had and or installed in other cars has the cut going to both fuel and ignition. Engine cant run without either of those so the only way they are going to take the car is towing it...
j3pz;1216405 said:i thought the ignition needs to be on to dump the clutch
jetjock;1216074 said:1) The factory theft deterrent system was standard in 1987. It should be in there. Gets a bad rap at times but fwiw the one in my car has worked flawlessly for nearly 22 years.
ZoomZoomZoom;1216429 said:BEWARE! Something supernatural is involved here! The Supra gods have blessed him doubley!
Easy to activate the factory alarm: 1. lock your doors 2. attempt to unlock your door with your key 3. lights flip up, flash, horn blares
YOUR FACTORY ALARM IS WORKING NORMALLY!
Sarcasm aside, I've had 4 sups and 3 of them had factory alarms that were possessed. The fourth I never locked. IMHO, unless you can find out which furry woodland creatures jetjock sacrificed to the supra gods, I'd dump the factory alarm. You're working with 20 yr old parts that are at the end of their life. And you are about to replace 20 yr old parts with more 20 yr old parts. When I install a new alarm it will be tied into a remote entry system. I know, more $$. I just hate fixing something I've already fixed once. Perhaps it may be easier to get a removable stereo deck and leave the car unlocked. A couple of guys have posted ideas for starter kills that would make it difficult to steal the car.
sai_supra1jz;1216225 said:The stock alarms is complicated:aigo:
QS: I added motion sensing (not shock sensing) to the factory system back in 89. It's located in the bottom of the center console. Keeps people from reaching in with the Targa off. It has to be setup right to avoid nuisance triggering though. I'm sure the stuff available these days works better.
vdragonmpc;1220058 said:I just ordered a replacement unit for my 5900SST viper remote start alarm from www.audiodimension.com (I think that was the site)
I paid 290 for it new and they have it with free shipping for 172$
I have liked this alarm in the supra a lot as I have remote start, hatch release and doors on it. I invested in rechargable AAA batteries which helped as its a 2 way alarm with 1 mile range. People like it mine just went stupid on me monday but I have a 5 year old and its possible he screwed with the remote.
Its not hard to install into the Supra and there is also a guy on here selling a great Clifford alarm and he has it all pre-wired up with detailed instructions. Im not too proud to admit I took some hints from his instructions.
Hookedontronics also has the newer color rechargable lcd remote
V
V
Poodles;1253518 said:So far as I know they all came with them.
Should be a Security LED on the dash.
Canuckrz;1253530 said:Where is it located on the dash? Because I can't seem to spot the little bugger. I'll take a good pic of the entire dash.
