shaeff;1226433 said:
I disagree ^ A 400rwhp Supra can be built reliably on a budget. You save lots and lots of money doing all the work yourself. Just a stock rebuild is plenty for 400rwhp, and a stock rebuild is inexpensive.
The differential will be fine, the w58 will last a while if you keep the hard launches to a minimum.
I meant in comparison to a moderate na,and on the idea of starting with an na chassis and going gte.I really don't see any reason an na can't survive on a stock rebuild bottom end,(knowing they will never see the kind of power that the turbo cars push on a stock bottom end,without issues)saving $ by doing the majority of the work yourself.Highest expense would be high comp. pistons,if you choose to up the CR.
Now starting with a car that came turbo
is an different story,and 400 rwhp would be "cheap" to obtain,but,if you have to buy all the turbo stuff,it will add up a lot quicker(gte block,ecu,harness,IC & piping, turbo, manifolds)And assuming nothing needs rebuilt(ie.engine internals.)
I would be extremely happy with anywhere near 250 rwhp in my na with the cost of a rebuilt motor.Already have every BPU available,and not that much into the parts,just caught real good deals on everything.I'm under $600 and so far have got
bx header,HKS MHG,ported head & intake,rc bored over TB,full toyota gasket kit,new rod and main bearings,K&N fipk,2 1/2" exhaust w/high flow cat and SS supertrapp muffler.Looking at ~1100 for the pistons/rings,and a set of cams,Machine work is free as I painted a friends '68 camaro for cheap in trade for that.Not gonna get everything to go turbo,w/a fresh rebuilt motor for less than the ~$1700 I'll invest w/o cutting corners and sacrificing reliability.
Also not looking for nothing real powerful,just a reliable,fun highway cruiser.
