Euro Gauges
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
I just bought a set of euro white face gauges from xrated89. They didnt came with instructions, so does anyone know how to install them? Do I have to remove my whole dash?
Someone :1zhelp: please.
How would I connect them to a power source as well?
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Maybe show some pics of what they look like, as there are different brands that do things differently.
I may be able to help.
xrated89
120
Canada
You have to pull the gauge cluster and take it apart and place these over the old gauge faces when installing them be careful of the oil pressure gauge it will come apart if you are not careful
you need to remove
1 the center console (piece with shifter and radio in it )
2 the piece with the fog light switch
3 the trim above the gauge cluster
at this point the cluster should come out
you will need to take the cluster apart remove the vents then the screws in the metal brackets and the front and rear it should just fall apart so if you find yourself pulling too hard you missed a screw
When you install the gauge faces you can remove the needles and replace the faces or you can put them on over the old ones but like i said watch the oil gauge it will come apart when you remove the two long screws be careful : ) anything else feel free to ask : )
