engine picker
Mine isn't bad, would have been nicer to have rollers on it, but it works and it's not like I use it everyday. Got my stuff from O'reilly's (engine stand, hoist, load leveler)
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Just a word of experienced advise, make sure the chains are SECURELY attached to the engine, the oil pan leaves a nasty dent in the bumper if the engine comes loose
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
gaboonviper85;1443886 said:
They are about $70
you don't need to remove the bumper...just Jack the car up enough and keep it up.
Lifting the engine isn't the issue, the one ton harbor freight doesn't reach in the front I tried it. When you start to lift the front digs itself into your bumper and will carve out a good 1-3 inches with the weight of the engine. I guess the 2 ton harbor freight picker has a longer boom iirc from an earlier post.
gaboonviper85;1443894 said:
Pretty cheap definitely worth it I'm done standing on my engine to get her in.
gaboonviper85
3,236
Northeast Philly
Poodles;1444014 said:
Shorten chains....
Won't help...I know exactly what his problem is...empera has the same problem but there was 3 of us holding the stand away from the bumper and 2 holding the engine back from hitting the cross member....he NEEDS a bigger lift with a longer boom if he isn't gonna have extra help.
Or get a chain hoist set up in those rafters up top of your garage...that would make life so nice!
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
I have the exact same one form harbor frieght. It worked just fine with my 1jz. Hoist from the front, and extend the boom all the way, and keep the rear of the car jacked up, while the front is down on the tires...
OneJArpus
2,798
never had an issue pulling or installing my engines with a harbor freight hoist.
Always go in from the front. Just push the car back install then push forwards. I've done it in a small garage next to a classic mustang (GT350) no probs
1st time no leveler. I use seat belts. It was actually easier with this then the leveler.
My cars too low for the legs to clear the control arms so i actually have to jack up the front of the car. Check harbor freight, i got a1 ton one for 29.99 IIRC
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Bumper assy is held on with 2 bolts. fasia is another 4 iirc. Removing them could solve this cheaper than buying a new hoist. May want to remove intercooler as well.
Bri7man
Jul 17, 2009
580
Torrance, CA
Awesome looks like next time if I don't have a new one I'll be removing the bumper and fascia.
I like gaboon's idea a chain hoist would be badass I'll have to look into that. The rafters up top are nice and solid.
