Engine management... what to use W/ 1JZ
Prettyazznouka
75
NYC
question.... is the safc1 and 2 that different from each other? Is there any particular advantage of getting one over the other?
tissimo
Stock is boring :(
Melbourne, FL
safc2 has 12 points of tunning vs the safc1s 8 points.. the afc2 also has the ability to store 2 different maps files.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Jostar;892691 said:
The knock detection on my AEM, i believe is disconnected, Sound performance didn't really need it, Alot of high horse power tuners don't need it.
Exactly, if you have to rely on knock dectection for a safe tune, then something is wrong with the tune or the engine/fuel setup.
tissimo
Stock is boring :(
Melbourne, FL
The safety feature is nice, but yea dont rely on it for a tune. But helps keep your engine healty. Logging the knock sensors is a great tool though. You can easily street tune your setup with it.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Alot of high horse power tuners don't even use the knock sensors, One of my friends with a evo II runs a Autronic ems & doesn't use the knock sensors, He hasn't blown any motor yet & has ran a best of 10.24 @ 142mph... Oh & that's with a master power T-70.
Jostar
May 21, 2007
746
Chicago
bigaaron;928124 said:
I have a knock sensor, actually I have two...... MY EARS!
Knock sensing is retroactive. If it detects knocking, it's because it's already knocking.
Knock Knock!! :biglaugh:
tissimo
Stock is boring :(
Melbourne, FL
there is very slight knock that you'd never hear, but the knock sensor does..
Its just an extra tool to help get the job done.. do you need it, no.... is it usefull, imo yes..
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Only thing I wish was different about the stinger is more aux inputs/outputs. Other than that I love the interface, and the simplicity.
tissimo;892530 said:
I guess if you're not going to use the features then yea, its pointless to spend the extra money even though the features are quiet useful. But then why not just get megasquirt which is 1/2 the cost of Stinger and does eveything you and the vast majority of SM members need.
Only reason I didn't use the MSII, and it may seem like a dumb reason.. I couldn't find an answer to if the MSII could read the CPS. I didn't want to fool with a trigger wheel.
figgie
Twin Cities, Minnesot-ah
MoTeC here, what is a KNOCK sensor? Oh you mean one of those thing to detect an event that has already taken place ;)
Knock sensors are worthless above 4500 rpm anyway, right when you are about to go into peak power production. To much engine noise to contend with.
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
I Agree with you, but those guys are Running VP import or C16 or higher right? Most of us run on 93 or 91, at that octane level and higher boost, im sure you would like your investment to be protected by everything gizzmo possible.
By the time you hear knock, the engine has already seen detonation or pinging.
Krister
Holset lover
May 2, 2005
159
Finland, Europe
rakkasan;890615 said:
No more worry of stock ECU failure, TOTAL control of your motor. Emanage is a glorified (but good) AFC. I ran one for a while, and was happy with it, but stand alone is rather cool. It takes a while (or it did for me) to work out some bugs, but there is definitely more power to be had. I'm still working on my cold starts, but all in all, it's worth it....
Can Emanage raise the rev limiter and adjust the timing?
csnow
Matthew 6:33
Palm Bay, FL
No piggyback can raise the rev limiter. To raise the rev limit, you need a Mines, Gforce, or other reflashed ECU. Some piggybacks have timing control like the MAP ECU 2, and I believe the emanage ulitmate does as well. From what I have read, the timing control on the piggybacks is not very good.
