EMS: Stinger vs MegaSquirt vs AEM vs ?
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Evilempire1.3JZ-GTE said:
I got my ECU i will be running with WOLF V500 with display
Verry good ecu the only better one is motec.
I would say the wolf ECU v500 is in second place with motect in the lead!
Any good tuner can tune the wolf ECU it is better easier and more flexible you compair to other ecus and you do the same thing but they have less tunning points and are less powerfull but it all depends on what you want to spend and what you want out of your ECU.
Copy Cat....., and you got a new wire harness to boot for the same price. How do you like that display!;)
The Wolf V500 has many more features built in than the Motec as it's a Gen 5 unit it's just a pity they're lagging on the software development..... (Motec can do pretty well anything your heart desires... for a price)
figgie
Twin Cities, Minnesot-ah
knock what??? ;)
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
There is ALOT more to megasquirt than just buying a pre-assembled board.
All the sensors you have to buy, engine harness, relays, fuses, ignition configuration, ect. ect. ect.
figgie
IJ. said:
Knock knock? ;)
hehe
on a another note
both the wolf V500 and the Motec x00 series ECU have the SAME EXACT PLUGS (Plugs "A" has 34 pins and Plug B has 26 pin with two not used). The pin assignment is nowhere near the same ball park though.
