viperkillertt;1394769 said:Cant change it. Mine are high resistance, and it is set to that. You had 550s in yours, right? I have 380s still. THe setting is 10-16ohm. I am just trying to get it to run so i know it works before i disassemble the engine and rebuild the turbo system with the GT35R i have. It is very frustrating because it should have been able to simply run when reinstalled on my engine. I never meant to tune it with this configuration. I just need to know the ECU works properly before i take my engine apart. I have run 6 or 7 maps with all sorts of fuel settings including the two Aaron made at driftmotion. Nothing is workingMike and I have tried ever posible ECU setting and still nothing. Car runs perfectly on stock ECU.
And yes, i did measure them. I believe they were 14.5 or 15.5ohm. Something like that. It was above 10, so i knew it was high resistance.
Actually that is not entirely correct. The injectors may be that resistance but the factory wiring for the injectors has them wired in pairs. With that said the actual resistance is half and the closest value on the stinger is 4.5ohms. I would verify that you have your injectors wired correctly. I have a feeling you have them in batch fire but are trying to run them sequentially?
